Recently, when building gSender from source files, I started getting an error:
# yarn build-latest
build-prod-app] > gSender@1.4.11 build-prod-app
[build-prod-app] > cross-env NODE_ENV=production webpack-cli --config webpack.config.app.production.js && npm run build-i18n-app
[build-prod-app]
[build-prod-app] `isModuleDeclaration` has been deprecated, please migrate to `isImportOrExportDeclaration`
[build-prod-app] at isModuleDeclaration (/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@babel/types/lib/validators/generated/index.js:2765:35)
[build-prod-app] at PluginPass.Program (/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/babel-plugin-lodash/lib/index.js:102:44)
[build-prod-server] `isModuleDeclaration` has been deprecated, please migrate to `isImportOrExportDeclaration`
[build-prod-server] at isModuleDeclaration (/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@babel/types/lib/validators/generated/index.js:2765:35)
[build-prod-server] at PluginPass.Program (/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/babel-plugin-lodash/lib/index.js:102:44)
[build-prod-server] DEBUG 2025-02-12 00:51:27.986667856 +02:00 sentry-cli version: 2.39.1, platform: "linux", architecture: "x86_64"
[build-prod-server] INFO 2025-02-12 00:51:27.987446631 +02:00 sentry-cli was invoked with the following command line: "/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@sentry/cli-linux-x64/bin/sentry-cli" "--header" "sentry-trace:3c542d0cef3045b8a4a598a268e192f8-9b71d81a3b1e329b-1" "--header" "baggage:sentry-environment=production,sentry-release=2.23.0,sentry-public_key=4c2bae7d9fbc413e8f7385f55c515d51,sentry-trace_id=3c542d0cef3045b8a4a598a268e192f8,sentry-sample_rate=1,sentry-transaction=debug-id-sourcemap-upload,sentry-sampled=true" "releases" "files" "359d9bbe7b9372dd9770ca6ff662477f0a7e989b" "upload-sourcemaps" "/tmp/sentry-bundler-plugin-upload-DoNW7S" "--ignore" "node_modules" "--no-rewrite" "--use-artifact-bundle"
[build-prod-server] DEBUG 2025-02-12 00:51:27.998904214 +02:00 request GET https://sentry.io/api/0/organizations/sienci-labs/chunk-upload/
[build-prod-server] DEBUG 2025-02-12 00:51:27.998938215 +02:00 pipeline: webpack-plugin/2.23.0
[build-prod-server] DEBUG 2025-02-12 00:51:27.998946712 +02:00 using token authentication
[build-prod-server] DEBUG 2025-02-12 00:51:27.998957208 +02:00 retry number 0, max retries: 0
[build-prod-app] (node:39027) Warning: Accessing non-existent property 'lineno' of module exports inside circular dependency
[build-prod-app] (Use `node --trace-warnings ...` to show where the warning was created)
[build-prod-app] (node:39027) Warning: Accessing non-existent property 'column' of module exports inside circular dependency
[build-prod-app] (node:39027) Warning: Accessing non-existent property 'filename' of module exports inside circular dependency
[build-prod-app] (node:39027) DeprecationWarning: Tapable.plugin is deprecated. Use new API on `.hooks` instead
[build-prod-server] node:internal/errors:983
[build-prod-server] const err = new Error(message);
[build-prod-server] ^
[build-prod-server]
[build-prod-server] Error: Command failed: /snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@sentry/cli-linux-x64/bin/sentry-cli releases new 359d9bbe7b9372dd9770ca6ff662477f0a7e989b
[build-prod-server] DEBUG 2025-02-12 00:51:27.893614764 +02:00 sentry-cli version: 2.39.1, platform: "linux", architecture: "x86_64"
[build-prod-server] INFO 2025-02-12 00:51:27.901746166 +02:00 sentry-cli was invoked with the following command line: "/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@sentry/cli-linux-x64/bin/sentry-cli" "releases" "new" "359d9bbe7b9372dd9770ca6ff662477f0a7e989b"
[build-prod-server] DEBUG 2025-02-12 00:51:27.907611455 +02:00 request POST https://sentry.io/api/0/projects/sienci-labs/gsender/releases/
[build-prod-server] DEBUG 2025-02-12 00:51:27.907624586 +02:00 pipeline: webpack-plugin/2.23.0
[build-prod-server] DEBUG 2025-02-12 00:51:27.907632267 +02:00 using token authentication
[build-prod-server] DEBUG 2025-02-12 00:51:27.907655961 +02:00 json body: {"version":"359d9bbe7b9372dd9770ca6ff662477f0a7e989b","projects":["gsender"],"dateStarted":"2025-02-11T22:51:27.907581566Z"}
[build-prod-server] DEBUG 2025-02-12 00:51:27.907663334 +02:00 retry number 0, max retries: 0
[build-prod-server] error: API request failed
[build-prod-server]
[build-prod-server] Caused by:
[build-prod-server] [6] Could not resolve hostname (Could not resolve host: sentry.io)
[build-prod-server] DEBUG 2025-02-12 00:51:32.917555979 +02:00 skipping update nagger because session is not attended
[build-prod-server]
[build-prod-server] at genericNodeError (node:internal/errors:983:15)
[build-prod-server] at wrappedFn (node:internal/errors:537:14)
[build-prod-server] at ChildProcess.exithandler (node:child_process:414:12)
[build-prod-server] at ChildProcess.emit (node:events:507:28)
[build-prod-server] at maybeClose (node:internal/child_process:1101:16)
[build-prod-server] at ChildProcess._handle.onexit (node:internal/child_process:305:5) {
[build-prod-server] code: 1,
[build-prod-server] killed: false,
[build-prod-server] signal: null,
[build-prod-server] cmd: '/snug/builds-pkg/gsender/src/gsender-1.4.11/node_modules/@sentry/cli-linux-x64/bin/sentry-cli releases new 359d9bbe7b9372dd9770ca6ff662477f0a7e989b'
