Errors (ID:25, 33) when trying to run the gcode
Hello, after generating the .gcode file with Fusion 360 and trying to run it on gSender, I encountered the following error:
X30.537 Y26.314
G3 X30.612 Y25.776 I0.164 J-0.251
error:25 (Invalid gcode ID:25)
error:33 (Invalid gcode ID:33)
I’m using the standard fusion 360 GRBL post processor.
Working with Genmitsu 4040 PRO MAX.
Hey Sekai,
Welcome to the playground. I believe there was a topic not long ago that included somewhat all your problems. It was fixed by connecting to the machine using grbl, not grblhall. might this be a solution to your problem aswell?
Read the topic here:
@Sekai The website is somewhat confusing to me. It says that the controller is running grbl, but that it is a 32-bit controller. I wasn’t aware that was possible. I’m sure that someone here can educate me. I thought that grbl was confined to 8-bit controllers.
@Sekai you might want to check your post procesor
@gwilki there have been many non-official, open source implementations of grbl over the years, many of which never made it to the mainstream so it wouldn’t surprise me if there was a version of grbl out there running on 32-bit hardware
@chrismakesstuff Tks, Chris. Live and learn.
This solution helped me resolve the issue, thanks!
