Files in what order?
Hi, I’m new to CNC, so naturally, I have a few questions. I want to create my first 2.5D wood relief. I already have the three cutting files ready. My question is: is the cutting order strict, or can I start with the clearing pass to remove the bulk of the material, followed by the roughing pass, and finally the finishing pass?
Hi @Andres3 - the order of your files is indeed strict - but the order you are describing is what makes most sense. You will generally want to work from courses to finest - and your finishing toolpaths will assume that the rough cutting has already been completed.
What CAM package are you using (or did you purchase these files?)
Hi, thank you for your answer! I am using F-engrave program!
