Hi all,
I am not sure if this is in the correct area for my question/issue.
I am working on a vcarve inlay in Aspire. My flat depth for the carve was set to 6mm as the project was made in mm. When I chose a post processor I mistakenly selected grbl inches. I typically build projects in inches. My machine is set up in gsender as inches.
The issue I had was the flat depth in the vcarve only went to about 4.75mm. If i build a project in mm is it a must to choose grbl mm and set the machine in gsender to mm as well?
I did check my movement calibration. On the X and Y i am within .0025ā on a 10 inch run. On the Z I am within .0012 on a 4 inch run. I had previously dialed in my steps pretty good I think.
