Flexible re-zero trouble
I am having difficulty getting the flexible re-zero. When the wizard gets to measure tool #1 nothing happens when I hit the run gcode button. The wizard will progress to the next step even though the bit was never measured. Nothing happens in the console after it says prepare for tool change. Not sure what I am doing wrong.
Post Processor with begin and tool change section.
begin HEADER
“(First tool T[T] [TOOLNAME])”
“T[T]”
“G17”
“G21”
“G90”
“G0[ZH]”
“G0[XH][YH]”
  • Command output after the header to switch spindle on
begin SPINDLE_ON
“[S]M3”
“M8”
  • Commands output for a dwell move
begin DWELL_MOVE
“G4[DWELL]”
  • Commands output for tool change
begin TOOLCHANGE
“M5”
“M9”
“G0[ZH]”
“T[T] M6”
“([TOOLNAME])”
“[S]M3”
“M8”
gcode for test
(VECTRIC POST REVISION)
(FFC3E011CE37EC2B3209C64EF366F5F1)
(First tool T1 UC221 - Upcut - 1/4’’ x 1’')
T1
G17
G21
G90
G0Z38.100
G0X0.000Y0.000
S18000M3
M8
G0X76.776Y48.234
G0Z7.620
G0Z0.000
G1Z-6.350F1016.0
G1X76.741F2032.0
G1X73.538Y48.467
G1X70.229Y49.213
G1X66.952Y50.513
G1X66.516Y50.774
G1X87.002
G1X89.674Y52.370
G1X90.788Y53.314
G1X62.730
G1X61.043Y54.742
G1X60.102Y55.854
G1X93.416
G1X94.846Y57.542
G1X95.355Y58.394
G1X58.163
G1X56.815Y60.650
G1X56.702Y60.934
G1X96.815
G1X97.823Y63.474
G1X55.695
G1X55.515Y63.927
G1X55.044Y66.014
G1X98.473
G1X98.749Y67.236
G1X98.845Y68.554
G1X54.672
G1X54.534Y70.457
G1X54.580Y71.094
G1X98.937
G1X98.752Y73.634
G1X54.765
G1X54.768Y73.678
G1X55.331Y76.174
G1X98.186
G1X98.003Y76.987
G1X97.318Y78.714
G1X56.199
G1X56.815Y80.265
G1X57.406Y81.254
G1X96.112
G1X94.846Y83.372
G1X94.489Y83.794
G1X59.028
G1X61.043Y86.173
G1X61.233Y86.334
G1X92.284
G1X89.674Y88.545
G1X89.123Y88.874
G1X64.394
G1X66.952Y90.402
G1X69.497Y91.411
G1X84.021
G1X83.289Y91.701
G1X79.980Y92.448
G1X76.776Y92.681
G1X76.741
G0Z7.620
G0Z38.100
M5
M9
G0Z38.100
T2 M6
(UC2175 - Upcut - 1/8"x 3/4" )
S18000M3
M8
G0X19.006Y31.664
G0Z7.620
G0Z0.000
G1Z-3.175F889.0
G1Y114.214F1778.0
G2X20.594Y115.801I1.587J0.000
G1X128.544
G2X130.131Y114.214I0.000J-1.587
G1Y31.664
G2X128.544Y30.076I-1.587J0.000
G1X20.594
G2X19.006Y31.664I0.000J1.587
G1Z-6.350F889.0
G1Y114.214F1778.0
G1X128.544
G1Y31.664
G1X20.594
G1Z-9.525F889.0
G1Y114.214F1778.0
G1X128.544
G1Y31.664
G1X20.594
G1Z-12.700F889.0
G1Y114.214F1778.0
G1X128.544
G1Y31.664
G1X20.594
G0Z7.620
M5
M9
G0Z38.100
G0X0.000Y0.000
M2
@Brettrc1 Welcome to the group, Brett.
A little more information will help those here to help you.
What machine are you running?
You have posted in “software other”, what software are you using? It looks like you are using a Vectric application.
What post processor are you using in your vectric application?
If you are using gSender, what version are you running?
Is this a new problem or has it always been present?
If your CNC is a Sienci unit, what firmware is loaded?
sorry,
Altmill 4x4
gSender- latest release, Vcarve pro 12.5-latest release
New problem. First time trying flexible re-zero
@Brettrc1 No worries, Brett. I can’t help you as I no absolutely nothing about flexible zeroes. However, it’s very likely someone here will be able to address your problem.
I have moved your question to the gSender category, as I am assuming that it is gSender related. If I am proven wrong, I will move it again.
Thanks for the report, it looks like the complete event was firing but not the toolchange callbacks for specifically flexible routine - I’ve verified the others are working as expected.
We’ll get a fix out for this in the next release, which should actually be this week.
