gSender 1.0.0 - Start at Line
I used the “Start at Line” feature after someone showed me where it was located. I use an IOT device and anytime I hit “Stop” the job stops and turns the IOT off as normal but if I hit “Start at Line” then the IOT does not turn back on. I have the M08 and M09 already in the gcode file header and footer.
Thanks
Hm, interesting. We’ll look into it, thanks Duane
Let me know if you find anything on this.
Thanks
We should have some fixes for this in the upcoming build - both to make sure the gcode:start event is firing on start from line and to make sure coolant modals are added to the configuration block of start from line if they are present in the file instead.
Let us know if it’s still an issue.
Cheers,
Kevin
