Gsender 1.4.12 update/help please?
i upgraded to 12 yesterday and nothing works now, i am super green, and even files that worked prior do not work now, i reset all of my gsender specs back to default so now my machine is not listed where do i go to set up my machine? and does it have to be connected to it to do this?
I would so be down if there was some classes to walk us through everything and how to do a simple file in carveco, and then set up in gsender, just to learn the basics… is there anything like this offered anywhere, i am trying to wing it with videos and such, but when you have no idea what you are doing or know anything about gcode, and how to fix it, it is very daunting to say the least.
Thanks for any help offered, step by step from beginning to end would be so helpful.
Michelle
@msyniuk If you have not done so already, you may want to explore learn.carveco.com. In addition there are several topics here in the carveo category that may help you.
Fixing gcode is another matter entirely. You really should not have to “fix” it as long as your carveco-generated toolpaths are good and you have chosen the correct post processor.
