Gsender 1.5.0 4 corner issues
I have a Sainsmart Genmitsu 4060 Pro Max
I had the Gsender 1.4.12 version and all worked great
I updated to the new version 1.5.0 and issues
The 4 corner buttons will not work. Even after HOMING over and over
make sure you are not on GRBLHall, look in the top left corner, if you are change in the settings to GRBL
I’m in GRBL… If I down grade to 1.4.11 or 12 it works fine but in the older versions now I’m getting Z plunging all the way down when I select X,Y Zero button lol that was not an issue before I upgraded to the new 1.5.0 version
I had similar issues. I can’t even use continuous jogging. I can home, jog right continuously then when I try to jog left I get a Error 15 ā€œjog target exceeds limitsā€. Looked at the console and it’s trying to jog 12 or 13 thousand mm. My mill is significantly smaller than that.
Then I homed again and hit the back right button and it locked up with Alarm 2 ā€œsoft limitsā€. Then I wiped the files and reinstalled 1.4.12. I won’t even try a carve if it can’t jog properly.
EDIT: I forgot to mention that while I was connected and jogging using single clicks I tried to open the firmware settings and it said I needed to be connected, I hit the connect button and then the settings appeared. I might try again later and see if having grbl as the fallback firmware type, instead of the default grblHAL, changes anything.
I even uninstalled the app and cleaned off the gsender folder and the two files under the USER folder. then reinstalled the 1.4.12 and still the same Z plunging all the way down LOL I just cant win
@LFloresTX when you’re saying the 4 corner buttons aren’t working, can you give some more explanation about what aspect isn’t working? Then I can know more information to help you.
Also if you haven’t yet updated to 1.5.1 or the upcoming 1.5.2 that should be out today then I’d definitely recommend it since it’s possible the issues you’re experiencing are resolved
