GSender 1.5.1 issues
Been having issues since this version was released
  1. The four corner options - all focus to the front left of the machine, Does not matter if I home it 100 times.
  2. The movement tuning - Just tried on the X - Axis, I mark the 1st location. Go to option two and it has 100mm by default. I select it and it jogs all the way over to the right until it hits the limiter. I tried again and only entered 10mm , it moved 4 inches, tried a third time and selected 100mm and it moved all the way over again until the limiter stopped it. I rehomed before each try.
  3. the Z axis movement of NORMAL default is .079, everytime I start the machine and connect to it this setting of .079 changes to .004 and I have to go into the config and tell it to revert this one to default.
@LFloresTX Iโ€™d recommend updating to 1.5.1 or even 1.5.2 which should be released this Tuesday since the issues #2 and #3 that you mention were both fixed as of 1.5.1.
Regarding the corner buttons movement, you can also try that again in one of the newer versions and if itโ€™s still an issue then if you could provide more information like diagnostic file, video, console, etc. then we could sort you out
