Default display is inches
Tools-Movement tuning tune X or Y, related issue in squaring tool
Step 2 of the wizard asks for distance to move in inches, and moves that distance
Step 3 asks distance moved in mm
When given the measurement in mm, it reports a huge error that appears to be (inch value minus mm value)
Sq tool shows the inches traveled as mm
If I ignore the “mm” prompt and enter the measured inches, the wizard accepts it and tells me x axis is tuned, no steps per mm error…
Update: given the mm/inch mixup, should I trust the eeprom update suggestions that are based on mm?
Last note, do your inch measurements in 32nds precision. 16th isn’t enough…
Sigh, freedom units for the fail!
