I wanted to test the wireless controlling through my phone. so I enabled it and hit save. The notification came up instructing that I needed to restart gSender. I did so and it will not get past the splash screen. I let it sit on the splash screen for over an hour.
I have tried reinstalling but it seems that my settings are saved somewhere. How can I clear this out and go back to default?
There should be a .sender_rc file in your home folder. Rename that and then look in either C:\AppData or the AppData folder in your home folder. You’ll need to have hidden folders visible in file explorer. Any gSender folder(s) in AppData can be renamed and then you can get a clean install.
I’m assuming Windows because that’s what the gControl ships with.
