In gSender 1.5.x there was a file (c:\Program Files\gSender\resources\app\main.js) that one could modify to allow gSender to blank the screen. This file seems to no longer be present in 1.6.
Has anyone figured out yet how to enable blanking in gSender 1.6?
I have sent a note to Sienci directly. If there is a solution I will post it here for anybody else that prefers blanking to be enabled.
If it’s not possible to edit the files directly, we can look at adding a config toggle for it.
Specifically, you were editing the powerSaveBlocker events previously, correct?
Correct, I would comment out the highlighted line and the two lines following.
1.6.1 will allow you to toggle the power saving via the “Power Saving” config option in the Basics section.
WooooHooooo !!! THANK YOU !!!
1.6.1 is now available - so your notepad++ can rest easy hopefully.
