Hi,
I’m using FluidNC (V4.9 controller) with soft limits enabled and machine coordinates set correctly.
My machine homes to front-left (X0 Y0) and everything works fine:
Homing works
Jogging works
Manual G53 commands work (e.g.
G53 G0 X900 Y1600)
However, when I press any corner button in gSender, I get an immediate soft limit alarm.
Console shows:
G53 G21 G0 Z-1
G53 G21 G0 X-975 Y-1695
[MSG:INFO: Soft limit on X target:-975.000]
ALARM:2
So gSender is sending negative machine coordinates, even though my valid range is:
X: 0 → 980
Y: 0 → 1700
It looks like gSender assumes a different machine origin or axis orientation.
Important:
My setup is correct (no inverted axes needed)
Manual G53 moves work perfectly
Only UI corner buttons are wrong
Is this a known issue with FluidNC or firmware detection in gSender?
Thanks!
