gSender disconnecting randomly mid project
gSender is disconnecting randomly mid project.
I’ve seen other posts where one of them said if they use another circuit for their computer this fixes the issue, but this didn’t happen to me until upgrading to 1.5x.
I used my longmill for long hours with 1.4.x and this disconnect never happened.
I already changed usb cables and it didn’t fix the issue.
FYI, I have my vacuum’s hose grounded by using a long copper wire looped around the hose which connects to a ground prong from an extension I plug directly to the same outlet as the vacuum.
again, I strongly believe this is related to 1.5x as it never happened to me before upgrading
J
J,ai le meme problems que vous. J,ai essaye la version 1.4 et le probleme est encore present
@NCNC Have you upgraded to 1.5.1? If so, is the problem still there? If not, you may want to do that.
@klaude Bienvenue au forum, Klaude.
Comme clarification, vous avez le même problème que @NCNC en utilisant la version 1.5.0. Correcte? Ou, vous utilisez la version 1.4.12 et vous avez le même problème?
Yup, I upgraded to 1.51 as soon as it was available, this happened with both 1.50 and 1.51
Thanks for the confirmation Klaude, guess I was lucky this never happened to me with 1.4x, then again, too frequently now all of the sudden and can’t help but see just the one change being the version.
@NCNC I suggest that you open a support ticket with Sienci. Using the added information that you will provide in the ticket, they will be in a better position to address this.
Le même problème avec des versions différentes…. Je n’ai pas réglé mon problème … cependant ce matin j’ai fait une mise à jour de Windows et gsender semble stable maintenant
@klaude Si la mise à jour de Windows a résolu le problème, je vous suggère de vérifier que tous les paramètres de réduction de puissance dans Windows en ce qui concerne USB sont désactivés.
J’ai vite réalisé que le câble USB allait me donner des problèmes de communication. J’utilise le port ethernet entre le Gcontrol et le processeur… c’est quand même un bon conseil! Je vais faire les réglages . Merci!
@klaude congrats that your setup is going well now!
@NCNC since this is originally your topic I won’t close this yet until you feel the issue had been addressed
Thank you Chris!
Go ahead and close it, I have not seen it happen again, and unfortunately I changed a few things (changed cables, changed software, reupdated USB Selective Suspend as Windows reset it to default), which means too many variables to be able to pin down what change may have potentially addressed this.
