Gsender normal speed reverts to zero
guys,
In configuration , customize ui, Precise Jogging,
then edit my xy speed to slow it down in Precise settings group, then clicks on Apply Settings,
after the settings are updated and saved, i see no difference in the speed the xy jogs at.
i have restarted gSender and no improvement.
is their another step, should i click the flash button after i click the Apply Settings button?
I have the same issue
Team,
Normal Jogging Preset changes every time I load gsender 1.5.0
I can reload XY, Z values and Normal Jogging Presets work until the next gsender 1.5.0 load.
I have the same problem.
Did you try using ā€œdefault ā€œsetting ?
I have the same problem also.
This should be fixed in the next release.
When I boot up. Rapid moves rapidly, precise moves precisely, but normal hums without moving.
The numbers are low or zero. I can type in a number and move that distance, but only that.
So I go to settings, type in numbers, apply changes and that works until I restart.
and next time I boot up it’s gone again.
@RobLM are you still on version 1.5.0? Since this should’ve been fixed for 1.5.1
You can also try going to Config and clicking the reset arrow for the normal jog preset value and that should unstick it
Thanks Chris, I just loaded an ATC, so now I’ll upgrade to 1.5.1.
i Also have this problem. The the values for jogging XYZ. Ive set them a few times only for the speeds to revert back. Im back on version 1.4.12 now.
Which version were you on, 1.5.0 or 1.5.1? Since this reverting problem was fixed in 1.5.1
i was on 1.5.0. I messed around for quite some time before downgrading
I installed 1.5.1 but it does the same thing for me. I went back to 1.4 for now.
@RobLM @Opiate1 @khull if you can try on 1.5.2, as well as go to Config and double-check that all the jog presets aren’t yellow (if they are then reset them)
Then let us know if the problem is resolved or still lingers
1.5.2 works. Thanks!
