gSender updated to 1.6.5 not connecting
Started up gSender, connection good, noticed an update so went ahead and updated it to 1.6.5, now it won’t connect. Have swapped with my laptop and nothing. Help.
@JimOutman power cycle the controller maybe? Or revert back to 1.6.4 to see.
You don’t say which controller you have. USB or Ethernet connectivity?
Have a Longmill MK3, Using Windows with a gControl panel.
Also have my Windows Laptop that I updated gSender on. I have cycled the power, disconnected and reconnected both the controller and the CNC controller many times. Still nothing. Even swapped out the USB cord. How do I revert back to 1.6.4? Thanks.
Did 1.6.4 connect fine on that same laptop before the update? That would tell us whether this is a 1.6.5 regression or something that changed with the USB connection itself. Also, when it fails to connect now, does gSender show an error message, and does the controller still show up in Windows Device Manager? Those two details usually narrow it down fast.
I was having the same issue and think it comes down either timing in the new gsender or lack of processing speed on the gsender panel so it doesn’t wait long enough.
Go to config > basic and turn off the ‘Reconnect Automatically’ and apply settings. Now when you start gsender you have to manually connect to the machine by clicking at the top left.
A bonus: since turning auto-reconnect off, I no longer have to press and reset the e-stop, as well as the other coms buttons on the e-stop and clear alarms before I can jog or home after startup. That had been happening every time with auto-reconnect on.
My guess is a timing race: auto-reconnect opens the port before the SLB has finished booting (or before Windows has finished enumerating the serial device), so gSender catches the controller mid-startup. It may only show up on slower PCs like the panel, which would explain why it isn’t seen in testing.
If they don’t already have it maybe Sienci can a short delay, increase the delay or a ready check before auto-reconnect fires.
