gSender v1.5.0 edge 8 quick question
I am playing with gSender v1.5.0 Edge 8. I have the notification for completed job enabled in the setup but do not get the popup when the job is finished.
Can someone confirm if the job completion notification is working in this version of gSender?
As far as I can tell there is only a single slider in the setup re this notification … correct?
I’ve been running it for about two weeks, and the notification hasn’t popped up. I think they don’t have it anymore.
Thank you, that answers my question. The basic setup still has the option to show/not show the notification so it would seem that the feature is broken or not yet implemented.
I went and looked at my settings and it did have a setting for confirmation and it was on, but it did work.
I assume that when you wrote ā€œbut it did workā€ you meant to say ā€œit didn’t workā€ .
I went out and checked my GSender and found out I had to switch in the software for it to work, and it was on, but it hasn’t worked since I started using it.
@Jens @fafesb this was something we spent some more time looking at and I think it got fixed 100% as of version 1.5.2 :+1:
