Gsender version 1.4.12
Just uploaded to version 1.4.12 this afternoon and now my buttons to reset to zero do not work anymore nor my probe. Is it a bug or should I look for something else
OK solved my problem by carefully reading the troubleshooting section. The solution was to correct the $10 setting in the firmware to $10=511
@michou I’m glad that you got it fixed, Michel. You may want to think about upgrading a bit differently next time. Before you upgrade, export your firmware settings to a file. After your upgrade, import that file back in.
