Gsender w/Genmitsu Wireless Controller
I’d first like to thank you all for any help and or feedback.
I am a newbie and have a Genmitsu 3020 Pro Ultra with the Genmitsu Wireless controller. Is there a way to connect gsender to the Genmitsu machine wirelessly? I tried putting the ip address of the Wireless controller into gsender but still won’t connect. Not sure if it’s a port issue or if it’s even possible.
Appreciate any and all help.
Thank you
I found this on GitHub Genmitsu-WiFi-Module-PC-Connect. Its about connecting UGS to a GGW-U232 Wireless Wi-Fi Module Kit. Not sure if that is the same controller or not but maybe it’ll point you in the right direction.
_Michael,
Thank you so much this is exactly what I was looking for… I had everything except the port number but this is fantastic. Thanks again so much.
If you could, let us know if that works out so it can benefit future users. You marked as solved but I’m not sure if that was because it you already got it working or just found some directions.
Michael,
Yes this worked perfectly and I am so grateful for your help.
