Hard homing and alarms
I just finished assembling my 4 x 8 alt mill. Excitement has been quickly dashed by alarms and issues. My first issue is the machine is homing hard into the corner. My second issue is I’m getting a number of alarms. If anybody could help that would be great.
check your dip switches to make sure they are set correctly. Some shipped with incorrect factory settings
@mattrock Welcome to the forum.
For homing issues, I suggest you home each axis separately. Under the coordinates, enable the toggle. The X0, Y0, and Z0 buttons will change to HX, HY, and HZ. Pressing those buttons will home the respective axis.
Try that and report back.
There’s also a pull off distance that you can increase in the Settings.
