Hitting the homing stops
I have a Shapeoko 3xxl which has been a good machine for the past 6 years and I decide to try Gsender.
When I hit the home button all is well and it appears to home with no issues. However if I toggle the x axis it will then move a little and crash into the side. In Carbide motion if I do the same it moves with the toggle buttons then stops and wont move further , never crashing into the side. What am i missing.?
Thanks for the support and advice
@Unclejoe36 Welcome to the group, Joe.
I’ve moved your question to the gSender Question board. It will get more traction here.
Not an answer but if you find a solution please post it. I also have a 3XXL and have thought about using gsender. I have an Altmill too and thought if I used gsender on both machines it might make it a little easier for me.
I’d check your Homing/Limits setting in Config to see if you have ‘Soft Limits’ enabled. This would stop the crashing you’re seeing
