Issues with G sender
When I load g sender program, I can load the file in and I get the error G code file closed. Top of G sender I get no connection and the disconnected does not change to connected. My XYZ I cannot move the cncin any direction. I have a Genmitsu PROVer XL 6050 Plus, my problem is Aspire 12.5. I am a beginner with cnc. Thanks for your help.
@john2687 Welcome to the group, John.
I have moved your question to the gSender category.
  1. What version of gSender are you using?
  2. Are you trying to connect with grbl - not grbl Hal?
  3. If you are running Windows, does windows see your controller?
I am using 1.5.6 G sender, trying to connect with G code.
windows does see the controller.
Hello John,
I would look at your machine configuration. I had the same issue setting up Gemitsu.
