History: I have an original kit version of an inventables X-Carve (1000x1000). It has been idle for about a year. It ran flawlessly using Vetric and picsender to create and carve files. Picsender disappeared from my laptop and I downloaded and installed the latest version. 3 laptops later, 2 died. I can’t find the new version of picsender (now an Easel product??). I downloaded gSender.
I set it up and connected it to the CNC (USB). It would not connect. Checked device management and it was not listed as a usb device, it showed up as xcarve in other devices, checked it and it indicated no driver available. Searching Easel’s site I found a driver EaselDriver_0.4.5.d4d27bc2ce.exe, downloaded and installed. The cnc now shows up as a serial device under usb. It connected. The Jogging controls were greyed out. Changed settings and it was active, or so I thought.
Current problem: When I try to jog to set XYZ to set zero I get an “error on line number. Undefined/ N/A “
I can still carve but the setup is really weird.
1: Disconnect the cnc from g-Sender. 2: Disconnect the machine from x-controller (using emergency stop). 3: Manually set XYZ to the material. 4: Reconnect the x-contoller. 5: Reconnect gSender. 6: Load job, (gSender assumes 0,0,0 for XYZ on connecting).
It works fine. I have to go thru the same routine when changing bits as well, Just the Z axis.
I downloaded Candle and UGS, Tried both. Got UGS to connect but did not like either. I like gSender’s interface, resembles picsender.
Would like to know if anybody has run across this or has any suggestions to try.
I did an AI search for you. This is the response. Working with the soft limits might help.
It appears your X-Carve is encountering a specific communication or firmware reporting error in gSender that is preventing the software from properly calculating movement commands, leading to the “undefined” error during jogging.
Potential Causes and Solutions
The behavior you described—where jogging is greyed out or throws errors, but the machine can still run pre-loaded code—often points to a discrepancy between gSender’s expected machine state and the actual GRBL firmware settings on your X-Controller.
Status Report Configuration: gSender requires the machine to report its “Work Position” (WPos) rather than just “Machine Position.” If this isn’t set, jogging controls may fail to update or return “NaN” (Not a Number) or “Undefined” errors.
Fix: Go to the Firmware or Config tab in gSender. Look for Status Report Options (often $10 in GRBL). Ensure it is set to include WPos. If there is a reset-to-default button for jogging presets, use it.
GRBL Version Incompatibility: The original X-Carve often shipped with an older version of GRBL (pre-1.1f). gSender is optimized for GRBL 1.1 or later. If your firmware is too old, it may send “Bad number format” or undefined errors during real-time jogging commands ($J).
Fix: You may need to Flash GRBL to a newer version (1.1f or 1.1h) through gSender’s Firmware tool or via Easel’s machine setup to ensure modern command compatibility.
Soft Limit Conflicts: If soft limits ($20=1) are enabled but your machine isn’t homed, gSender may block jogging because it thinks the move will exceed the machine’s boundaries, resulting in an “undefined” target or “Error 15”.
ix: Try disabling soft limits temporarily.
Jogging Speed/Rate Resets: In some versions of gSender (notably 1.5.0), the “Normal” jogging speed can randomly reset to 0, which triggers “Error 22: undefined feed rate” when you try to move.
Fix: Check your Jogging Presets in the Config menu and ensure the feed rates for Rapid, Normal, and Precise are all set to positive values (e.g., 500–2000 mm/min).
Again this is an AI response. Someone here might know more.
Thanks for the info. I tried the soft limits first, no help. I just flashed the grbl on the x-carve to 1.1g and it appears that has cleared the issues. Probing works, jogging works.
