Laser offset not working
Using 1,62 and latest firmware, Place values in offset boxes. When switch to laser and PWM the setup returns to where I started with spindle, not to where offset values should adjust to laser location. Any thoughts ??
Bart 54
Is your laser on PWM or PWM2?
the laser an opt is on PMW2
I’m seeing the expected behaviour on the latest grblHAL release. I’d need to know a bit more about your setup and specific board/firmware version (latest version for EXT is 20260525). You can see firmware version in the machine information dropdown:
On the SLB-ext running the above release, confirming that $770 and $771 are set in config:
Swapping from PWM (main spindle) to PWM2 (laser) correctly updates the offsets - I’m able to set zero point, swap to laser, then go to XY 0 and start the job. Offsets are handled on the firmware side entirely without gSender intervention as you can see in the console - we just send the spindle selection command and refresh the list.
Similarly, swapping back to regular spindle, the firmware is again correctly offsetting:
Things to share/double check on your end:
  1. Which specific version of the firmware are you running - “latest” doesn’t help. The first new grblHAL release we did did not include laser offsets.
  2. Double-check that you applied the offsets and not just entered them.
  3. Confirm $772 is set to 0 (otherwise G92 is altered which would result in the offset seemingly not changing from your perspective):
    REFERENCE: COMPLETE SETTINGS REFERENCE
