Machine Stops moving - GSender keeps going
Longmill mk2.5. CC router. Shop -Vac dust collection. USB connection.
While the job/cut is running the Machine stops moving but GSender doesn’t know and keeps going. The current line being processed keep incrementing but no more movement by the motors.
Is this indicative of static or USB vs Ethernet?
Since the GSender still seems “connected” not sure if USB.
Looking at Disconnection During Jobs – Sienci Labs
I can’t honestly say if it said “Disconnected” or not but since GSender kept going, I would think it was still connected. On Linux Mint. I can’t imaging the USB sleep is an issue here it was only about 5 minutes in (again maybe not “Disconnected”). I could switch to ethernet…but again was this even a connection issue?
@Witchdoctor Did this only happen once or can you reproduce it fairly easily?
Well …after troubleshooting more. I am almost shamed to admit. It was just a toolbit change. I am shocked there is not some kind of popup to log message to tell you this. I was further confused because evidently the lines numbers continuing to grow were the GSending being behind the actual executing line I believe.
Wondering if you are using an older version of gSender?
