@Dallas Changing $30 from 255 to 1000 will not make a difference in the power. You can use either setting. The important thing is that Smax in LB and $30 are set to the same value. As I explained above, as long as Smax in LB and $30 are the same value, you will be fine. Either of them represents the maximum power setting for the laser output or 100%. $32 turns on laser mode. I strongly recommend that you read the excellent documentation that LB provides. Here is a very short except that describes what $32 does:
“The more recent versions of Grbl (1.1f and up) support two things that are incredibly useful for lasers. The first is Laser Mode, enabled by setting $32=1 in the firmware settings. Laser mode eliminates the pauses that happen when changing power output, because Grbl knows it’s controlling a laser which reacts instantly, instead of waiting for a spindle to change RPM.”
Thank you for taking the to explain that to me. I have updated the setting, no big difference as I was using 255as my setting. Today I have been using Vetric VCarve Pro with the Laser Module to create some tests and saving the gcode and using G-Sender to run the laser. The last test I ran was a simple circle. The laser was moving at 25 inches per minute at 100% power in DIP 5 with 10 passes, and it still failed to cut thru a 4mm piece of foam core. Needless to say I am very disappointed and underwhelmed by this laser. Am I just expecting too much or is there something wrong with either the laser itself or my setting still?
@Dallas Using the Vectric laser module injects more variables. I don’t have the module.
I am confident, though, that the laser will cut as you want it to. I would be willing to bet that your problem is your VCP setup.
I assume that you’ve watched the Vectric videos on their laser module and have set your “tool” up properly. If you will post your .crv file, I can take a look at it, if you like. As I say, I don’t have the module, but I can do a fair job of faking it.
Are you using air assist to cut? Again, I don’t have air assist, but I may be able to compensate for that loss.
Keep at it, Dallas. We’ll fix this.
Oh, one final question. Is the foam core white? If so, that will add to your difficulty. Diode lasers don’t like white. It reflects, rather than absorbs, the laser energy.
@Dallas Tks for the compliment. Just so you know, though, I don’t work for Sienci. I’m just a user like you, and I moderate this forum.I am only saying that so that you know that anything I tell you is my own opinion and not necessarily Sienci’s position. In other words, don’t blame them. That said, I agree that they do offer excellent customer service.
When I mentioned the VCP setup, I was referring to the “tool” specs that you have entered for your laser. They can be touchy to get right.
If you continue to have problems cutting foam core, post your crv file. I have lots for foam core lying around can could see what your settings do. What lens are you using? I assume that you have focussed it properly.
Good to know but you represent them well. I am using the standard lens that ships with the Sienci laser and it is focused laser sharp (see what I did there?).
Keep us posted on how you make out. I’ve watched more videos than I care to admit to on using the laser. Clearly, this not a plug and play toy/tool. There are more variables than I realized.
I can highly recommend Rich, the Louisiana Laser guy for information on LB and on how to set feed rates and power levels. He has a forum, a facebook page and a youtube channel. One of his most recent videos addresses the issue of users asking people who post their projects what their feed rate and power settings were. He correctly points out that no two lasers are the same, no two pieces of wood are the same, etc. (A big thing for lasers is the moisture content of the wood at the time it is burned, for example). He offers for free a couple of test charts that you can use to show how any given piece of work will cut or etch at set feed rates and power settings. I strongly suggest that you download them from his forum and burn them. I have a few. One for mdf, one for baltic birch plywood and one for maple. Even with them, you will only be in the ballpark. The humidity level of your shop on the day you are using your laser will affect the outcome. gSender partially accounts for this by allowing for changes to feed and speed on the fly.
Finally, keep in mind that if you are cutting through material, you should have that material sitting on something that is open, not your solid MDF spoilboard - honey comb material, for example. Not only do you want somewhere for the smoke to go, but you don’t want to be setting your spoilboard on fire. DAMHIKT.
Just throwing this out there as a suggestion. I don’t have the laser you are talking about but I have experience with them.
By what you are describing you may also be dealing with a focus issue of your beam.
Make sure that you have adjusted it to as fine of a point as possible at the height it enters your material. Not the 0 height of your table.
Another thing that can be a problem is the color of your design in the software. If it is for instance red instead of black some softwares will lower the power. Every color is assigned a grayscale and a corresponding power to get the effect of different shades in your burn.
I engraves beautifully but I still cannot get it to cut even foam core at 100% power, 25in/min and multiple passes. I even tried painting the foam core different colors.
Why did Sienci decide to go with such a weak laser when there are so many more powerful options. Was it a cost thing? I’m finding 7w is just inadequate.
@Dallas I can’t speak to why Sienci went with the power that they did. I can say definitely, though, that the published power rating of the majority of the diode lasers available as add-on modules are greatly exaggerated. Many publish power consumption and not output. (The "5w generic Chinese lasers, for example.) Others say that their laser is a 10w, when that is peak output for short intervals, not continued output. Finally, some of the rated 10w lasers truly do achieve that output. However, they do it by over driving the diode, resulting in a short lifespan. (LED flashlight makers do the same, just as a matter of interest.)
From what I have read in Ikenna’s posts, the rating of the Sienci laser is an honest rating at continuous output. He may want to jump in here to explain better than I can.
WRT to your foam core issue, as I offered before, I will scare up a scrap and see what I can see about power and speed and post it here.
In the meantime, can you post as to what your results are for 3mm wood?
I have the sienci laser and have absolutely no problem with the power. If anything it burns too deep. It could be you need to update lightburn if you are using that
@Dallas I finally scared up some 1/8" foam core, painted it black and tried to burn through it. Now, I have an advertised 10w laser using a G8 lens from Sienci. I do not have air assist. With this setup, it was virtually impossible to cut through the foam core. I tried several power and speed levels and changed the number of passes. At one point, I set fire to the surface of the material, and it still did not cut through. I can only conclude that something in this material is resistant to the laser. (I can cut 1/8" basswood with no problem.)
So, I would suggest that if you have a lot of this to cut, you have two options. Use a 1/16" downcut end mill. I tried that can got very clean cuts. You could go even finer, but some of the very fine bits that I have break if you look at them sideways. Or, use a drag knife. There are a few designs on this forum if you want to go DIY. If not, there are many commercially-available ones online.
Thank you for the feedback. I will work on getting some thin plywood and testing the laser with that. You mentioned basswood. Do you recommend anything else? I know Home Depot has 5 mm underlayment that is relatively inexpensive.
I have the lens that came with the laser and just bought the g8. Can you share the difference in your experience?
@Dallas 5mm will be pushing a diode laser, Dallas. I doubt that you will get any joy trying to cut that. Nothing to lose by trying, though. I had some bass wood lying around. Locally, I can also buy birch plywood in 3mm. I can also buy 1/8" mdf. It cuts well, but scorches easily. It may work well with an air assist, but I don’t have that to try. If you do try that, make sure that you have good smoke extraction. The fumes are nasty owing to the resins used. (Smoke extraction should be used for any burning.)
As far as lenses, the G8 is not the best for cutting, as I understand it. I just used that for this test, as I was installed and I was too lazy to change it out. I believe that the G2 that comes with the Sienci laser is your best bet for cutting. I don’t have the lens.
@Dallas I get it locally here in Ottawa Canada. Both are available on Amazon.com in craft-sized pieces. If you have not already done so, look on the LAHobby Guy’s forum. Among other things, he has lots of free calibration files to download. He uses basswood a lot.
There was a wonderful review and communication string written by the team when they were investigating the possibility of a laser add-on. You may want to search back for those updates if you are interested in the ‘Why’. They delve into the variability of strength from the 10+ W chinese lasers and such.
