My machine will not move
Can someone please help. My machine will not move. X,Y and Z. When I try to move it I get an error code 22 ā€œUndefined Feed Rateā€. I do not know what that means. Can someone please help?
@scamp333 You’ve posted this in ā€œother softwareā€. Are you using gSender? When you say that your machine will not move, do you mean that you get this error when you use the X, Y and Z jogging buttons in the GUI?
I don’t know where else to post this. I am using gsender. I mean that I get an error # 22 ā€œUndefined Feed Rateā€ when I try to jog my machine and it does not move. X will not move. Y will not move. Z will not move. Where should I post this.
Hi Steve,
What version of gsender are you using.
For what I have read throughout the forum, 1.5.0 was a bit wonky on jogging.
It is said to be resolved in the 1.5.1 release.
Mabe installing that version may help you out?
@scamp333 I’ve moved your question to the gSender category. You may want to open a support ticket if @Spamming_Eddie suggestion does not resolve your problem.
Thank you. I am new to this forum and have not learned to navigate it yet. Sienci labs told me how to get it moving again. Again thank you for your help.
@scamp333 Can you describe the solution for the future benefit of others with the same problem, please?
Steve didn’t mention the fix in our emails with him either, but I’ll take a guess that he did as @Spamming_Eddie mentioned which was to download 1.5.1 to fix the issue, then go to Config → Basics → Jogging Presets and reset the ā€˜Normal’ preset back to its default value. If this is set to zero then you’ll get the Error 22 ā€œUndefined Feed Rateā€
