One inductive sensor not working
Installed a SLB on my Longmill MK2, but now my Z inductive sensor doesn’t work. It won’t light up when metal introduced to it. I plugged it in to the working Y input on SLB and still nothing. It worked fine prior to installing SLB. How likely is it that it broke coincidentally at the same time as installing the SLB or am I overlooking some setting in Gsender?
@brewpickles The only thing I have to offer is to make sure the pins inside the connectors are not bent.
I took the pins out of the connector and they appear intact.
The one thing I would test, before concluding a bad this or that is plugging a known good sensor into the z connector and see if it still detects/works.
This way you can eliminate either the sensor or/and slb to be the culprit.
