Brief:
Auto Probe. Outline looks and sounds like it’s jogging towards the machine 0,0 (front left) maybe
which possibly messes up the steps
Outline ends at gSender 0,0,1 but the but is at a new location loosely about 10,0,1
Video https://imgur.com/a/kBPrhyp (not sure if you can really see or hear the Jog - ?towards machine 0,0)
More Detail:
Sienci Longmill MK 2.5
GSender 1.6.3
Auto Probe
No limit switches or auto homing.
I do an auto probe and after it sits at 0,0,1 as expected
When I run outline I hear a little grinding and it looks like its trying to go towards actual machine 0,0
(front left). I could be wrong on direction as its pretty quick.
WHen it does the outline it goes past the end of the stock XMax (idk 15 mm? guess. Lets call it ERRORDIST)
Then on the return side,
when it gets back near Stock Xmin it does appear like it goes all the way to actual stock XMin
but it finishes with the bit at Xmin + ERRORDIST (eyeballing)
It’s a bit odd that the back side of the X returning to Xmin is going all the way to the edge of the stock.
I would blow it off as the file being bigger but Zero is no longer where it started.
Note, I am already at XMin for the left edge of my stock. So it shouldnt be going left anymore.
I could maybe more the stock over a few mm but its tight.
Still kind of new at this.
Previous was setup, flattening and tramming.
I had to troubleshoot step issues but it turned out to be I accidentally changed the resolution. Fixed that.
Followed that by running the same auto probe, outline and successfully cut a two sided (3D) wooden spoon carve. No issues.
So not 100% sure if this is outline issue/bug or some kind of step issue (It worked before). Probably missing something silly.
Thanks
