Reposted due to forum crash:
In gSender 1.5.3, the outline function seems limited in the size of file it can process. Simple outlines work fine but when I tried to outline a 9 MB file, the outline function consistently timed out.
Based on some minimal testing on the latest version, v1.5.4, the outline feature does take some time to process larger files, but it does manage to run the outline after some time. Can you confirm if you are running into the same problem on v1.5.4?
I am still on 1.5.3 for the time being but will test things once I update.
Thanks
