Park and corner buttons do not come on
Longmill MK1
Longboard
PWN spindle
gsender 1.5.1
Home button, P button, and corner buttons don’t come up, also the RPM slider does not show up. Tried to use grbl, and grblhal same results. Any ideas other than go back to 1.4, and that worked perfectly. Also the spindle delay doesn’t seem to work.
you need, limit sensors, max travel set in settings, activate homing in settings, set min max rpm in settings and so on
Thanks, but all of the above are set. I do have limit sensors. It does home when I first start gsender, but if needed to re-home it, I need to restart gsender.
Finally got the Home and P buttons to work. Spindle delay just does not want to cooperate. Also the corner buttons work wonky. I like the new features, but 1.4 was so much simple and easier to use. In 1.4 I had a custom post prossesor for the spindle delay, but I don’t see a way to put that in 1.5.
What is the place where you had the spindle delay set up before? I can point you to the new location so you can get the same functionality.
For other people who find this thread, what did you change to get the Home and P buttons to appear and work? Also can you explain more about what you’re finding to be wonky about the corner buttons?
I used to use a custom post processor (for spindle delay), and don’t see an option to use it, only one option for a MK1. Spindle delay doesn’t seem to work in 1.5.1. Not sure why the H and P buttons started to appear. When I hit a corner button, it goes and slams in the wrong corner, when it works. Maybe 1.5.2 comes out it take care of some problems. 1.4.12 works perfect.
I think I might have the problems solve with 1.5.2, just have to get it to run the spindle speed correctly. It tends to run full speed on startup, but can be be changed with the slide bar.
I am having the same issue with my longmill MK2 slamming into the front left corner whenever I hit any corner buttons.
