Parking & Rapid Travel Alarm
Hi all!
I’ve been struggling with a problem for some time now, and finally hit the point of reaching out to solve this: Hitting the Park button or any of the four Rapid-Travel buttons on the gSender control screen immediately triggers an Alarm 2 for exceeding soft limits. The machine does not move at all, the alarm triggers immediately. This happens regardless of where the Parking location is set to, if I’ve used the “grab” function to set it, or typed in coordinates manually. Hitting the “go to” command in the configuration screen also causes an Alarm 2 - even if I’ve just grabbed the current location as the Park location and have not moved anything. I’m not sure why this is happening, and haven’t been able to figure it out. Parking seems useful, I’d like to be able to use it.
I’m running a LongMill 2.5 12x30 with the induction sensor kit and gSender 1.6.4. Homing is enabled, works fine, and the machine was homed for all testing.
can you use my build and see if it works for you? i had this issue too and fixed it myself, im just curios if you still have that , give it a go and let me know
https://github.com/iuliancalin/gsender
