Pause and stopping mid carve longmill MK2
i just downloaded the latest update today and have a multiple issues.
Window 10, gsender says version 1.4.12 done off the update available feature in gsender.
Simple vcarve file, it stops mid carve and i have to restart it multiple times or it “pauses job” on its own with no input from me, i have to resume the job.
on a profile pass it went 1/4" past the depth and cut into spoil board then when going to home position it carved across the project and ruined it.
@wpheck Have you run this file successfully in previous versions of gSender?
yes, i also tried other previously run files and same thing. constant pausing or lock up during the run.
@wpheck Tks for replying. I suggest that you open a support ticket with Sienci. I have not yet installed 1.4.12, so I have no point of comparison.
Since 1.4.12 I am getting this same thing. Fortunately it doesn’t lose Zero and I can use the “start at line number” feature to continue, but I didn’t get these stalls on older versions.
This weekend I’m going to revert to an older version and see if it goes away.
Update: I tracked it down to a Windows Update had changed my power settings. The Device Manage USB settings flipped to allow USB to Sleep. I know for certain I had disabled that feature when I first got the longmill. I am now running GSender 1.4.12 without problems. As soon as the last Win10 update is pushed at EndOfLife my plan is to turn off Internet Access to that computer so i don’t need any Security Updates. That should prevent that from happening again.
@LewisB314 As you have resolved your issue, Lewis, I will close the topic. Thank you for reporting the solution.
