Hey folks, I was hoping gSender would probe a bore for center. I have error free operation with my Nymolab NBS-6040 using the Generic machine type and grbl (not grblHAL). Outside zeroing with XYZ, XY, X, and Y work fine with my PGFUN 3D Probe, NC. I will be replacing it with the NO version since the Z-probe the came with the Nymolab 6040 is NO as well. I hoping this will obviate the need to switch pin invert when I switch probes. In the Probe Config portion of gSender, I do not get options to probe inside a bore to find its center. Is this function not available in gSender, not available with my machine, or is there a setting I am missing? Thanks.
Not available natively. Custom macros for center probing are available via Neil Ferreri.
Outstanding!!! Thank you so much, Kevin!!! Gemini had me pulling my hair out convinced it was a native function of gSender. I really appreciate this macro and your lightening fast response!!! Best wishes for you!!
Stu
