OK, I found out “how” to Zero the Y Axis with the touch probe, but it appears I should not click the Zero button in Gsender after I zero it.
Just now I tried to mill a 0.5mm pocket in some MDF. I used the Z axis touch probe and went to do a test cut. My end mill carried out the test cut but the tip of the endmill was just barely above the surface of my material. Movements in the X and Y axis appeared OK.
I figured it was because I forgot to click the zero button after using the touch probe. However, after clicking Zero the end mill moved at the height of the Z axis probe above my material, so it appears I should NOT zero the Z axis after using the touch probe. It looks more like I have to enter a bogus number a little bit smaller than the measured probe thicknessto force the spindle down a little to make contact with my material.
Is this the correct procedure?
Also, kindly brace yourselves for lots of questions. I was going through the Settings menu in Gsender and encountered many terms I have never seen before in 4 years of using DrufelCNC with my old Genmitsu 3018-MX3.
Thanks in advance
Ken A
So Phisai Thailand
