Ring LED that will fit on Sienci's 1.5KW spindle?
Has anyone found a Ring LED that will fit on Sienci’s 1.5KW spindle? I have looked at dozens of models and all of them are either too large or too small to fit around the base of the spindle without touching the shaft. Even the one that is referenced in the SLB’s reference manual won’t fit :frowning:
Rob
The only ledring I own is the one fitting my microscope so when reading about ledrings my head spins into that direction. Microscope ledrings mostly try to mimic natural light, are dimmable and tend to be made adjustable to fit different brands of microscopes.
I think this one would fit.
They are also… costly. But if everything else fails - who cares, right?
@rblondeau You might find this thread useful. There are a couple of links for lights that other members have installed.
