Roughing Blank Planner - Plugin (BETA)
All - I am working on a very audacious plugin project and would love some collaboration help on the features, capabilities, and testing.
The objective is to create a tool that consumes a final part nc file and designs a roughing blank that can be cut from an inventory of billet stock. Ultimately it will provide the nc file for cutting out the roughing blank along with the mounting/clamping/fixturing layout to be used for the final part machining.
I have a proof of concept started that collects what I think are key parameters on the billets, tools, clamps, vices, and bed layout then generates the nc file for the roughing blank.
If you are interested in collaborating on this please IM me.
TIA
I’m starting to wonder if you ever sleep! Are you an android? You’re a plugin machine that’s for sure. :grinning_face:
I’m sure people are grateful for your work.
P.S. If you make one for height mapping I think you’ll achieve gSender immortality! No pressure, it just seems to come up frequently if you run out of things to do. :wink:
Ha - I actually have 2 of them - Here
@bakStaaJ I don’t want to hijack this thread but since I could not find a post you started specifically for your height map plugin, I’ll ask here. Does it work with a 3-wire 3D probe? I also see that you sell a simple and low cost probe on your web site. There is another thread discussing different probes for the SLB so I’m sure others would be interested about that.
I realized that you probably meant engraving height map - The surface map plugins that I created are for applying a leaving algorithm to an NC file - primarily for engraving PCB’s that must be very flat and you can also use it to probe a surface and develop an STL of the surface. I just built this image heightmap plugin that takes a picture, converts it to greyscale and then generates an engraving heightmap from it. gSender-Plugins/image-heightmap-engraver/v0.1.3/README.md at main · bakstaaj/gSender-Plugins · GitHub
@bakStaaJ No, I think we both had the same understanding for what the height map meant. You probe an existing surface for any deviation from flatness, and then apply a correction to an existing gcode file.
My question was whether your height-map plugin would work with a probe like this:
I already use it with another sender that does height maps or, as they call it, 3D mesh.
Edit: I just installed your plugin to try it out and ran into several issues when trying to use it. If you want to create a new post for this plugin, I’d be happy to post there. Like I said, I don’t want to hijack this post.
