Router not turning on automatically
I don’t think this really a bug but here is my problem. I am using the original Longboard controller and running Gsender 1.5.7. Have not used the machine since I upgraded software due to medical issues. I was working on a project yesterday and my router would not come on when I started the program. After going thru settings I finally figured I had to turn on Coolant to be able to manually turn on the router before starting the program. It would automatically turn off when the program was complete. My question is ther a setting that will automatically turn the router on when the program starts or do I need to spend some money and upgrade to a SLB?
Hey @Oldfolks,
Welcome back!
I’m assuming you are using an IOT Relay via the coolant port on the LongMill. You will need to ensure you have an M8 at the beginning of your code to start the router, and an M9 at the end to turn it off.
Check out these resources for more deets.
Cheers,
Stephen
Thanks Stephen. What the problem was I forgot to go back and add M8 &M9 after I figured out I had to have the Coolant Controls active . Alls good now , thanks for shaking my brain .
Jerry
