I’m waiting on a replacement X motor (due to be delivered tomorrow afternoon) so I’ve had time to overthink everything I’ve done up to this point.
In the assembly instructions, when assembling the gantry you use a clamp to tighten up the face of the gantry on the motor side, then tighten the screws. Does the other side just get tightened up after or did anyone use a clamp to pair up the right side as well?
I took a look at mine and it was sitting cockeyed, so I loosened the screws and sucked it up with a clamp before tightening up the right side..it moved a good 1/16" or more and the right side is now square with the gantry plate.
Was this a legit concern or am I fiddling with things I should just leave be?
Thanks!
(That dang motor needs to hurry up..
