I wanted to share a recent experience getting gSender Edge 1.6.0‑5 running reliably on a Raspberry Pi in a headless configuration, in case it helps others or informs future docs.
Setup
Raspberry Pi running 64‑bit OS
Initially used the AppImage, later switched to the
.debinstalled under/opt/gSender_Edge -
Remote access from macOS via Safari to
http://cncpi.local:8000 -
GRBL controller on USB
What I saw
With a monitor/keyboard on the Pi, gSender could see and connect to the USB GRBL device without issues.
From Safari on my Mac, the gSender web UI would load, but it showed no USB devices and could not connect, even though the Pi itself was talking to the controller just fine.
At one point, the Pi behaved correctly headless in the past, which added to the confusion.
Root causes I eventually uncovered
Wireless Control was disabled in the new
/optinstall-
The original AppImage instance had Wireless Control enabled, so
cncpi.local:8000was serving a live backend. -
After switching to the
.debinstall, Wireless Control was off by default, so the new gSender instance wasn’t exposing a remote endpoint even though the local GUI worked.
Safari was serving a cached copy of the old gSender page
Safari happily showed a cached version of the remote UI for
cncpi.local:8000even when the backend had changed or wasn’t actually reachable. -
That produced a very misleading state: the UI “looked” fine, but underneath there was no real backend, so no devices appeared.
A hard reload (Command‑R) would have forced Safari to revalidate and would have exposed the real connectivity problem much earlier.
Launch method mattered (desktop vs systemd)
I ended up standardizing on a
systemdservice that runs/opt/gSender_Edge/gsender -H 0.0.0.0 -p 8000 --remote trueat boot as my Pi user, with no need for a desktop login. -
Once that was in place and Wireless Control was enabled, the behavior became predictable and survives reboots.
Current working configuration
gSender installed from the
.debin/opt/gSender_Edge -
gsender.servicesystemd unit launches it at boot (headless) -
Wireless Control enabled; remote access via
http://<Pi-IP>:8000 -
Logs:
Service:
journalctl -u gsender.service -b -
App:
~/.config/gSender/logs/main.log
Suggestions / feedback
It might help to:
Make it very obvious in the UI when Wireless Control is disabled or when there is no active backend for the page the browser has loaded.
Add an explicit headless Pi + systemd example to the docs for the
.debinstall. -
Maybe note in the docs that browser caching (especially Safari) can show a stale gSender page; a hard reload can save a lot of debugging time.
I don’t think any of this is a “bug” in gSender per se; most of the confusion came from switching install methods, Wireless Control defaults, and browser caching. But having a canonical headless‑Pi recipe and a bit more feedback in the UI would help folks avoid the rabbit hole I went down.
