SLB Jog Control Settings Won't Stick
I have installed the SLB and haven’t located this topic in the discussion. I can’t get the settings to stick in any mode, Rapid, Normal, or Precise. Each box reverts to ā€œNaNā€ on moving from one mode to another. I’m running version 1.4.10 grblHAL.
Hi @Wills this is actually coming from gSender not the SLB. What you’ll want to do is go to the settings gear, and change the values for the 3 jog types, and once you do that it should fix the issue you’re seeing
Beautiful! Thanks Chris. I installed it because you asked me the other day how I liked it. I think I’m going to like it a lot. I have the panel computer on order and will order the router replacement when it’s ready. The magnetic LaserBeam mount is wonderful. Good job to Ikenna and the team!
Amazing! I’ll let the rest of the team know, Did the fix work?
Yessir!!! Thanks for your quick help.
