Soft Limit Errors - Close to m/c physical limits
I’m trying to run a large (area) file for my machine - Genmitsu 4040. The machine has a working limit of 400mm x 400mm, and the file I’m trying to run is 390mm x 380mm. When trying to Outline or Run the program, it returns a soft limit error. I’ve confirm the soft limit for both axis is set to 400mm. If I zero the machine, I can manually jog each axis to 400 with no errors. The project is a Vcarve sign so I could reduce my overall size, but prefer not to have to do this. My gSender is ver 1.4.11 - its been working fine (until this) so I haven’t upgrade to newer versions.
Thanks for any feedback provided
TM
So found my error - after I set my Z axis to the correct location everything works fine. Definitely a brain fart moment!!!
Cheers
