Soft Limit travel value shared when X and Y home at same time
The soft travel limit is “shared” between the X and Y axis if they are selected to home together. If I make them separate homing events then the respective soft limit travel limit values are observed. Gsender latest, MK2.5 30X12 and SLB.
@whittamps can you explain a bit more what you mean by this?
Thanks, I will try. If I select the homing order setting to home X and Y at the same time when pushing the HOME control, the soft limit value for the Y axis becomes the soft limit value for the both Y AND X axis. If I change the homing order settings to home X and then Y (or Y then X ), the respective soft limits for each axis are employed and full soft limited travel is enjoyed on each axis. If we check the soft limit settings they appear as correct for the axis respective travel sizes in all cases. This is on my student’s MK2.5 30 by 12 with SLB not on my MK 1 from the kickstarter days (which is still kicking ass and making money btw). I hope this helps.
If it’s appearing correctly in the Config settings, then when you’re encountering the soft limits I assume it’s when you’re jogging around? If this is the case this would seem to me to be a firmware issue potentially
