Well not sure what happened i used the rotary to create the skull, the next day went to make another and mid roughing pass it just froze, i wanted a few minutes and hit stop in gsender, no codes other than me stopping the job.
Tried it again and now only the A axis spins and the spindle does not turn on, in gsender it shows spindle on. No codes until i hit stop and then i get code 14.
Ive tried everything i can think of, i can manually turn the spindle on in gsender, i can use m3s10000 to turn it on. Just cant get it to turn on while using the vortex.
I did load a non rotary file and did an air test, the spindle turned on for that, so im at a loss and need help.
Altmill 4x4 1.5.5 gsender vortex rotary.
