Anyone know where i can get the file, if there is one, to print off some of those wire clips that go into the slot in the extruded aluminum on the altmill to hold up the stepper motor wires?
Look in this thread if youโre talking about the wire holder that twists in look further down the thread not the starting message
@gremlin go to sienciโs website and click on the resources tab. Select Altmill. On the left side of that screen scroll down to the hand book section and select Open Source. Then select the link for I assume Altmill mk 2 for you? Then after the page loads, at the bottom of the screen there are tabs. Select the hardware tab. Then select the Misc tab. Then select the Altmill 3DP Cable Hanger tab and export/download it in the file format you want.
AltMill 3DP Cable Hanger.stl (84.2 KB)
@Dnick you meant to put this to @Chip I believe I Was answering his question but was not on a device where I could easily copy the answer, thanks for putting it in-line
Thanks everyone, i appreciate the help and links
