1: The file displayed in the visualizer will disappear when changing view angle but the stylus stays and moves with the cut. Is the file image painted in memory only once?
2: It would be handy if the line number was added to the console to accurately indicate the true location in the gcode. The start-from seems to be about 5 lines ahead and I usually correct it before restarting.
3: When restarting a job the spindle is not allowed to reach speed before cutting. I set the SETUP to 5 seconds and it seems to only affect initial job startup and adds to the pause in gcode I added in pre-processor .
Thanks for the submission James! Regarding your first point could you explain more what youāre seeing and confirm that you still see it in gSender version 1.5.3?
Regarding your other two items the reason for the line number being off has to do with another area weāre looking into where since gSender strips out blank lines and comments it often means that the line that we think it is compared to the actual file is different. Also to your 3rd point I just noted another, older request for the same thing so weāll be looking into it ![]()
In reply to first point, I still see the issue of disappearance of vector (Tool Paths) drawing when I inadvertently clicked on the āFeatherā causing the astronaut cat to appear and when I clicked the feather again the grid lines and stylus reappeared (following the cut) but the vectors (Tool Paths) did not. They could only be restored by reloading the file.
Regarding the issue for the restarting after a pause, I go to console and issue a gcode (s22000m3) or whatever speed was set, to restart spindle before restarting job.
Tnx, Jim
Using app image on 64 Bit PI
Hi @wb8eye, Iām refreshing this topic since:
- I can see that your original point #1 is still present
- If you try a newer gSender Edge version you should now find that the console line numbers are now more accurate than before since we updated how we do line counting
- The spindle speed-up time should also now be addressed on newer gSender versions
For points 2 and 3 could you let us know if they look fixed on your end once you get the chance to try them?
@wb8eye due to no reply, and since Iām confident points 2 and 3 are now addressed, Iāll close this topic - however since 1 still is outstanding as a potential enhancement to gSender Iāll make a new topic for it
