Tool change wizard - The final “Resume Cutting”
When using the full tool change wizard and you get to the last part “Resume Cutting” gsender just hangs. I have noticed that if, instead of pressing run at this point in the wizard, you cancel out of the wizard and simply press the Start button in main screen things work as expected. Although this works, it’s quite a lot of additional button presses.
I should say I’m using V1.6.4 on a Window machine, sending to a Shapeoko.
Using which strategy? Also Shapeoko, so grbl? It seems to be working as expected with testing.
Hi Kevin.
Thanks for prompt response.
Yes Shapeoko is using grbl. I am using fixed tool sensor, tool change location and Always run full tool wizard.
This often works as expected on the first tool change but then fails on subsequent tool changes.
Regards
Peter
Hi Kevin. Have you had the opportunity to explore this issue further?
