Trouble with gSender and Huanyang VFD
I’ve been having trouble getting the default spindle to work with my Hyunyang VFD. I’m using the SLB as the controller. What does work is if the default spindle is set for the SLB_Spindle and Spindle 1 is set to the Hyunyang VFD. It works perfectly doing that. However, I have to remember to use the drop down menu and select Spindle 1 every time I cut a job. Sometimes I forget and things get freaky.
If I set the Hyunyang VFD as the default spindle and leave the remainder of the list as inactive (last option), I either get an Error 14 (tried 0 and 100 time setting). Or it will recognize it and just show that it’s running, even though it is not.
I read several topics regarding this or similar problems and believe I have tried all the advice from them. I just want to be able to open gSender and have it run the VFD without having to remember to set it every time. It seems like a simple thing I’m missing and hoping it is. I appreciate any input on this - thanks for reading.
@matt which version of gSender?
