Using G54/G55 issue
I don’t know if this is a bug or not, but I was doing two projects on my Alt Mill 24x48 the other day and when I was going to the next tool file for the G55 (2nd) job, the location parameter changed to G54.
I only noticed it because the visualizer indicated the home position of my first or G54 job.
The interesting thing is, when the first tool for my G55 job finished, the CNC went to the G55 home position. It wasn’t until when I was loading the next tool file, that apparently gSender change my working space to G54.
Is there a parameter or other change that can be set so gSender will stay in whatever workspace I select until I chose to go to another or back to G54?
Thanks, John Kuiper
Hey John,
Welcome to tthe forum.
I believe this have seen this issue a few times in these here forums. And have found an answer from way back in the days referring to the problems and fixes page of gsender. Have you seen this?
https://resources.sienci.com/view/gs-feedback/#workspace-changes-duringafter-a-job
Hope you can find your fix inhere.
@JohnnyL I’ve moved your question out of the Bug category. I believe that you will find you answer in @Spamming_Eddie post.
Please report back when you have resolved this.
Excellent. Thanks for the link. I’ll give that a try the next time I run two or more projects.
