V1.5 - Normal Jogging not working
I installed 1.5 no issues, running my first project and i cant jog in the Normal setting, Rapid and Percise work fine, no movement when i select Normal.
Jog “precise “ and “normal “ are reversed .
In my experience .
Go into settings and change to default , it should fix it .
Thank you., reset worked.
This was a bug in 1.5.0 that has since been fixed in 1.5.1, so hopefully you won’t have any issues anymore once you update :+1:
